iPhone 3G keeps losing signal/service
Problem:
iPhone 3G loses signal randomly and for no obvious reason, everything else works just fine.
Circumstances:
- Until a few days ago the phone has never been dropped. Then it was dropped from about 1 meter, twice...
- The phone is just over 1 year old
Tried:
- Waiting
- Nothing..
- Rebooting
- Brings service back for a while
- Activating and deactivating flight mode
- Re-seating sim-card
- Brought back service initially, but didn't solve problem
Theories
- Loose cable?
- I don't see how that fits in. I mean, re-booting gets the service back. If it was a loose cable it shouldn't help to re-boot..
- My observations indicate that the phone is only ever on 3G network. Could the problem be in or around the UMTS chip?
- Considering logic board replacement or contacting someone doing BGA soldering.
Update 1
Yesterday I changed the whole dock assembly to see if that could fix the problem.
Today it lost connection again. So it didn't work.
Now I'm considering to get a new iPhone or doing a logicboard replacement on this one.. Also I could find someone local that does BGA soldering and ask them to find the chip that has to be loose on the logicboard...
Either that or I'll decide that I can't afford it because I just bought an iPad....
I also added a third theory.
Either way, thanks again for all your help and comments!
Это хороший вопрос?
11 Комментариев
if the phone logs onto anetwork - how long will it keep the service until it looses the connection again?? - does it also happen when the phone lies on a table, at the exact same spot as before ?
из markus weiher
The phone stays connected for a very varied amount of time. From 10 minutes to a few hours. It loses connection in my pocket as well as laying on a table. I can't guarantee that it was in the exact same position on the table thou.. But I'm off to bed now, late here. So it will stay in the same position for the next few hours.. Responding to any comments or answers in the morning.
из rousp
right it's late here in europe (00:21) ;-) - i think the problem could come from a antenna problem or a contact problem (maybe some bga soldering connection problem)
из markus weiher
Let's hope it's not a bga solder at least.... I've just decided that I couldn't afford the new iPhone, being a student...
But, why would a contact problem be fixed by re-booting or the flight mode thing?
из rousp
The contact problem could be "minimal" and if the phone comes to a not that good covered area - it simply looses the connection. but it could also be a hardware issue and the phone isn't able to "sync" the service settings that it receives from the BTS (base transceiver station) - and that is one possible point where a phone get's kicked from the network
из markus weiher
Показать 6 больше комментариев
