Repair your Dyson DC 14 vacuum cleaner with a part replacement guide.
Вопросов 20 Показать все
No suction. Air comes out of small vent.
All of a sudden my dyson dc14 stopped working. When you turn it on, it starts fine, but after about 2 seconds you hear a loud hiss (air) and all of the air is directed out of the tiny vent above the filter. Everything is clean and seems to be connected properly. Could something not be air tight? I'm out of ideas.
Thanks!!
Это хороший вопрос?
Оценка 10
24 Комментариев
There is a little cup above the dust/garbage collecter mine was covered in hair/dust... Empty that and it will stop!
Same issue I cleaned the filter emptied the bin but forgot to check that little cup!!!
из
That did not work for me!
из
How do I find the little cup?
из
in my case, there is a small short hose behind the ball. That hose was clogged. it's pretty easy to disconnect the hose and unclog it.
из
Finally! I found someone who has the same problem as me! My Dyson DC40 had the hiss of air come out after a couple seconds as well. Hardly no suction. I tried everything. Both filters were clean and canister was empty. But, the problem IS in the canister. I know that because when the canister was detached, and I turned the vacuum on, there was no hissing sound. Attach the canister, turn the vacuum on, and there comes the hissing sound. You have to take the filter housing out of the canister. There's a permanent mesh filter surrounding the innards. This was completely clogged with dust and fine plaster dust (yes, I know I shouldn't have vacuumed that up...but I did). Anyway, I took a brush and cleaned the mesh off, then tapped it on the ground to remove even more stuff. Voila...it worked! I have a new vacuum!
из
Показать 19 больше комментариев
Добавить комментарий
Ответов (5)
Выбранное решение
There are two maintenance guides that you might go through. How to Clean the Dyson DC14 Cyclone/Internal Channels, How to remove and clean the Dyson DC14 filter
Dyson DC14 Изображение
Инструкция
Сложность:
Легко
10 - 15 minutes
Инструкция
Сложность:
Легко
5 - 10 minutes
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
I have this problem right out of the box. The other issue is that my Dyson 's brush just keeps stopping. This vacuum was just unboxed 10 minutes ago.
из
Margie you need to just take this one back
из
To add to mayer's response. The air redirection is an indication of a clogged dirt intake (this is done to prevent burning out the motor) The re-direct commonly when the dustbin is too full.
In theory you don't want the Dyson's dustbin to get completely full. When this occurs the vac becomes slowly less effective as it packs more and more dirt into the bin, and more likely that debris may not be handled properly and resulting in the dirt intake becoming blocked.
More likely and in my case the dirt intake blocks when an item which is slightly longer or wider than the dirt intake channel airway can accommodate at one point or another. Problem areas are the U-bend, the bend just before the dustbin, and the accordion hose just after the brush bar.
Problem is that an item is able to be picked up by the vac and it doesn't immediately clog, and the user is unaware that the dirt intake is partially obstructed. Over time items catch on the same piece of debris obstructing the dirt intake and eventually cut the suction to the point where the suction redirect kicks in.
Checking these areas (and any other areas where a narrowing of the dirt intake occurs) you should locate a blockage and clear it. (I use a inexpensive piece of semi-flexible rubber hose to snake through mine to clear it when this occurs. (avoid metal or harder plastics as they may puncture or damage the intake channel)
Note filters when properly cleaned will allow you to see light (commonly a bright light will allow you to see a little light through each individual piece of the filter sponge or filter) through the filter media if it is properly clean and dry. (if you can't see any light at all clean and dry the filter again until you do.
Also ensure the Cyclone assembly is not clogged with any debris. Tapping on the side of the inside of a solid garbage bag is normally sufficient to dislodge accumulated dust, but because there are many small holes within this part it may have a lot of accumulated dust. Wiping the inside of the cyclone helps with the exterior dust but not the dust that has made it's way up into the chamber. So the tapping from different angles will dislodge this dust and it will "rain" out of the unit. Doing this also improves the performance of the filter between cleanings.
Оценка 0
1 Комментарий:
Have just separated the cyclone assembly from the clear bin. Then banged the cyclone assembly on the floor. Two litres of very fine white powder immediately fell out (must have been caked around the seven cyclones). Now sucks perfectly. I guess it was too light to fall into the clear bin.
I once cleared a bathroom fan heater, clogged with talcum powder. Could be the same problem.
из
I'm having this problem on a 2015 model Dyson Animal upright vac which does not have a prefilter. The bleed off port will open after only a few uses, even though the dustbin has been emptied each time and never near full capacity. The problem is a layer of felted dust clogging the screen on the internal part of the canister. If I pop it open and brush away the dust layer with the vacuum's brush wand, it immediately works again, but only for about 2 uses. A Dyson support girl told me that dust clinging to that screen was due to static build-up inside the canister and that rubbing the internal components of the canister with a anti-static dryer sheet would solve the problem. But dust continues to collect on that screen. So I'm about to send it back for warranty repairs. :(
Оценка 0
Two additional tips that may be helpful:
1. I used a dryer lint brush (long, small diameter, and somewhat flexible) to clean/clear several of the passages that were too deep or long to dislodge items that were potentially causing my Dyson to loose suction.
2. My filter had gotten a lot of buildup underneath the blue mesh top. I'm ordering a new filter but in the meantime I cut the mesh open, cleared the buildup, and stitched the mesh back together so I could use it.
Successful return to full vacuum suction.
Thanks for everyone's advice
Оценка 0
I have a problem when using the wand on my DC-14. I’ve cleared/cleaned everything, but it appears to be the part that diverts air/suction. When I first turn it on with the wand free, for 1-2 seconds it sounds normal, but then the sound changes and there’s little suction from the wand. It’s find when using the floor/carpet part.
In that little vent on the canister lid beneath the handle, I see some sort of flap that looks like it’s not working properly (not sure if the vent is supposed to be open or closed when using the wand)—when the sound changes the flap is half open. I haven’t tried to unscrew that black plastic part that has a spring on it, which covers the part where the flap is.
Оценка 0
1 Комментарий:
Hi Debbie,
It sounds like a similar noise that I was hearing when I would start mine up. Does it only happen when you use the wand? Mine happened with the wand and/or the main vacuum. If you take the debris canister off the machine there is a gray button to remove the plastic housing so that you can pull the section with the handle out. Towards the top of that piece there is a black mesh screen. Dirt and debris can build up on that and if it does it will kill your suction. I know the flap you are referring to and I thought that’s what my problem was, but it was actually that screen was clogged. As soon as I pulled the dirt/debris off of it, everything worked fine. Just sharing my experience.
Hope this helps!
-Alan
из
Добавьте свой ответ
Vinny Troia будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 10
За последние 7 дней: 23
За последние 30 дней: 101
За всё время: 136,377
