A business-class desktop PC, sold in multiple form factors and configurations.
when I press the power button nothing happens.
There is an led on the MB indicating that it has power but when i press the power button nothing happens. All the cables are connected and there is no visible damage to the motherboard and other components.
Это хороший вопрос?
Счет 5
Добавить комментарий
6 Ответов
I would check power cord first...then check the power connection
Был ли этот ответ полезен?
Счет 0
Hi guys, I have the exact same problems. I have checked the psu and power connectors, and the front card power button, they are all fine. The bios chip gets really hot though.
What can I do?
thanks
Счет 0
1 Комментарий:
my guess would be electrolytic capacitors in the power supply are going bad
purchase another similar P.C - put your hdd & ram in it - doesnt cost much
из
Replace the motherboard. It'very easy. While doing that add 3.8 processors and AMD 5450 video board. Put all 4 gigs of memory. Add 1 terabyte hard drive. Install Windows 10 and you,'ll have a nice running computer. But the motherboard alone will solve your problem, You can get them cheap on EBay.
Счет 0
I’ve had the same problem and I have a answer for it. There should be a green pin inside and if it’s on the “RTCRST” pin move it to the “PSWC” pin and that will work.
Счет 0
Brother this is problem of your front Power panel card unplug the front button power card and on PC directly or replace front card of power!
Счет -1
check processor chips
Счет -1
Добавьте свой ответ
Joran Geeraerts буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 2,055
