Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36474вопросов Показать все
Speaker/ringer not working after digitizer replacement.
I changed the digitizer and now the owner of the phone says the ringer doesnt work, also the ringer which I believe are the same. Where are the speakers because I opened phone back up and checked connectors 1, 2 and 3 and they are fine. Any help would be appreciated. Thanks
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
i only can guess that you are talking about the 3g(s)
the buzzer is inside the dock connector
so i would first check cable 4 if it's well seated and contacts of the ribbon in the middle/left - it would make sense to watch out for broken components in that area!
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Mark Stuper будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,398
