Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75вопросов Показать все
Вопрос закрыт
Bottom left corner is bent, is it repairable?
So basically my phone got smashed in between a car door. This not only shattered the glass (and I assume the display) but also bent the bottom left corner towards the front.
I'm wondering if this is A) Repairable and B) Worth the cost of repairing?
Its approx $200 for the screen and display alone, but I don't know whats damaged on the bent corner. I have not tried turning it on. Pictures available if needed.
Thank you so much for your time!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi, Bolin,the glass had shattered and the bottom left corner is bent that will effect the button. So you need to replace the LCD+Touchscreen ,just approx $140
http://goo.gl/dlhCQ2
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 402
