In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
211вопросов Показать все
Where to buy flex ribbon cables?
I've been searching on eBay for all 4 flex ribbon cables that my PS3 Super Slim CECH-4001B uses, but I have found only ONE cable that is from that model.
Will these work?
Two of these 6-pin, one for the power button and the other for the lid open/close switch.
http://www.ebay.com/itm/Hot-6-pin-Eject-...
One of this 9-pin, this one goes under the power supply.
http://www.ebay.com/itm/NEW-9-Pin-0-5mm-...
And this 45-pin one is for the BluRay.
http://www.ebay.com/itm/Flex-Ribbon-Cabl...
Will the first two fit? are they too expensive?
Это хороший вопрос?
Оценка 3
2 Комментариев:
Did these cables work for you? I need a 9pin flex cable for my Super Slim.
из
Unfortunately I never got around to buying any, I convinced myself they were too expensive and decided to give up on my PS3.
из
Добавить комментарий
4 Ответов
I need a ribbon for the super slim that hook up under the power supply to the disk motor not for the laser please help me idk how pins it has pleasel et me know
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
That's a 9-pin connector.
из
Was a 9-pin accurate?
Оценка 0
To anyone going through this problem the ribbon cable is a 9 pin forward 1.0 mm pitch 50mm length flex cable they can be obtained from eBay but from China
Оценка 0
2 Комментариев:
PS all cables are like $10 for Blu-ray
из
Do you know the pitch for the 45pin as well as the 6pin cables as well?
из
I have a question.. Hoping someone can help me.. I'm trying to figure out what white cable that is to the left of the disc reader is so I can purchase it!! So I can buy the right one
Оценка 0
Добавьте свой ответ
Gabriel Velez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 44
За всё время: 5,377
