o First clean the surface of the disc with a soft lint-free cloth. You can use a gentle detergent (or rubbing alcohol) if there are some grease spots. Make sure there are no finger prints or dust particles. Don’t scrub too hard as you may do more harm than good this way.
o Now apply some toothpaste or polish on the scratched surface. It is best to start with a minimum amount of either, or else you will have your work really cut out trying to buff away the remainder.
o Now rub gently with a cloth moving from the center outwards.
If you did a good job, you will actually see the scratch diminishing, or if it was a faint one, it might just disappear.
The success with this method varies greatly. It is hit and miss. I have had an equal amount of successes and failures. Sometimes it works allowing you to even read data from that part, other times it is of no use at all.
IN case guide above can't help you or your CD is severely corrupted, visit next source:
https://discuss.howtogeek.com/t/how-to-r...
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
