Why will my Kyocera Event not turn on?
The phone will not power on when holding down the power button.
Это хороший вопрос?
Это хороший вопрос?
Hold down the power button
Press and hold down the power button (on the right side, top of the phone) to turn on the power.
Dead battery
1. There is a chance that your battery needs to be recharged. Try plugging in the phone to your charger and give it a few minutes before holding down the power button.
If the phone fails to turn on, it is likely that that battery no longer works and needs to be replaced. To replace the battery you need to find a compatible Kyocera battery, remove the phones backing, and remove the old battery. To remove the old battery you will lift up on the white tab labeled “pull” that is placed on the bottom of the battery.
If this step also fails it is possible that the charger may be faulty and needs to be replaced as well.
Был ли этот ответ полезен?
I tried this and replaced both the battery and charger, and it still won't turn back on. Please help!
My phone just don't turn on or off ....it has a white line from top to bottom in the middle of the screen
My phone does nothing
i keep putting my charger in and then it does'nt even works
Activate a minute cell phone from a Sprint SIM card
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 15,309
