This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
How do I fix the sound on my phone?
The media and all the ringers are all not working even though it says it isn't on silent. When I plug in the headphones, then it works and its the only way I can watch videos.
Это хороший вопрос?
Счет 139
23 Комментариев
My speaker is not working how do I do it if u got urs to work...please... Thanks a bunch
из
I'm having the same problem. Did you ever get it fixed
из
I got the same problem
из
I had to install an app called SoundAbout from playstore.
из
When I make call people on other end can hear me but I can't hear them, volume is all the way up and when I get call it only vibrates
из
Показать ещё 18 комментариев
Добавить комментарий
2 Ответов
Выбранное решение
it seems to be your main speaker (Ringer) faulty. you may have to replace it
Был ли этот ответ полезен?
Счет 19
25 Комментариев:
How do I do that ?
из
did you ever figure it out???
из
I replaced my speaker and it still isn't working what can I do now
из
Backup all data and reset the phone. check whether speaker back to working condition, otherwise you have to check audio out/ amp section carefully
из
Показать ещё 20 комментариев
Turn Bluetooth on and off
Счет 14
10 Комментариев:
Worked like a charm thanks bud
из
Was having same issue.. Came here for answers...saw a thread that said turn Bluetooth on and back off....worked for me...
из
Thank you I'll try that
из
Wirked like a charm wow
из
из
Показать ещё 5 комментариев
Добавьте свой ответ
Jamie Duque буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 26
За всё время: 200,312
