Guides for gas and electric stove, range, and oven repair.
181вопросов Показать все
Вопрос закрыт
Searching for electronic shop for Control Panel diode replacement
A replacement panel is no longer available for our Harman Pellet Pro II Stove that has been discontinued. It has been suggested that we find an electronic shop that could replace the burned out diode. Any recommendations?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Kathy Boser, I guess this will depend on where you are located. Rebuilding the control panel could be a good idea and might even be straight forward, for as long as it is the diode that has failed. Some pictures and more of a description about what happened to your stove might even give you a better answer.
Был ли этот ответ полезен?
Оценка 1
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 90
