The Panasonic HDC-TM15 is a 16 GB full HD camcorder, released in 2009. Repair for this device is straightforward and requires common tools.
2вопросов Показать все
The zoom button is stuck to one side.
I have a Panasonic HDC TM15 video camera and the zoom button is stuck to one side and won't move. My optical zoom won't function properly and it is making it difficult to use my camera. Does anyone know how I can fix this issue?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
First, check if there is anything preventing your zoom button from moving from side to side. There might be dirt or residue preventing it from functioning properly. If there is some sort of blockage, take a toothpick and carefully scrape away at the dirt or residue surrounding the button. This should remove most of it, but just to be sure, take a cotton swab with a solvent on it, such as rubbing alcohol, and wipe away the area surrounding the zoom button. This should solve your problem.
If there is still an issue, your zoom button may need to be replaced.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Nicole будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 433
