Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36472вопросов Показать все
iPhone generations, difference between 1st and 2nd gen
If one goes to the iPhone identification page of iFixit one finds 4 model numbers and iPhone generations
A1203 - 1st generation
A1241 - 3rd generation
A1303 - 3 Gs
A1332 - 4 G
Is there a second generation iphone? I have seen that descriptor before. What is the model number for the second generation?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Sterling is correct. Also, there is no such thing as an iPhone 4G. It is an iPhone 4. It does not operate on a 4G network. By calling the second generation iPhone the 3G (they called it that since it operates on a 3G network), Apple convoluted a common naming convention to call things 1G, 2G, 3G, etc.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
wasn't there 2 versions of the 1st gen iPhone? the june release in 07 then in november they released a second Version with changes to the Battery? i got my first in nov of 07. I think when Apple refers to the iPhone 4 as (4G they meant it to be the fourth generation. both David and Sterling are correct.
OK i was mistaken the price drop in sept when apple discontinued the 4GB iphone
so the time line its iPhone 1 Edge, iPhone 3G, iPhone 3GS, iPhone 4.
из
Наиболее полезный ответ
A1241 is not 3rd generation, it's 3G. The 3G is the second generation iPhone.
Оценка 4
Добавьте свой ответ
drprice будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 28,653
