The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
52вопросов Показать все
Вопрос закрыт
speedometer in vehicle only works sometimes
I haven't done a whole lot to get to the bottom of the issue. I did, however, replace the transmission speed sensor, but that wasn't the case. Now I'm going to disassemble the cluster and look for anything out of the ordinary. Any info on this subject would be greatly appreciated.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I had this issue; I ended up buying a second hand speedometer and swapping out the circuit board, that way I kept the original mileage. Has worked great ever since.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 369
