The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0. Released in July 2013.
443вопросов Показать все
Galaxy Tab 3 Not Charging properly Damaged Port
My samsung galaxy tab 3 10.1 kept disconnecting from charge i sent it off to samsung and they told me i had to pay
£92 to repair it even though i got the tablet for £180 i have checked my charger it appears one pin has gone missing and now when i try to charge my tab with any charger i have to hold it in a certain way for it to charge also when i use my offical charger a red x appears i was wondering what needs changing and if it is suitable form a complete newbie to do
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
The 10" Tab3 has the USB port on a flex cable that plugs into the motherboard. Very easy to replace.
The 7" and 8" have the USB port directly soldered onto the motherboard. I wouldn't suggest trying this unless you have soldering experience or want to learn. I replace them using a hot air station and desoldering equipment.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
deon ska будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 249
