Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Difference between ipad mini lcd and ipad mini 2 lcd
Hi, I have a bunch of iPad mini LCD's and I'm curious if there are any physical differences (not talking about resolution here) between ipad mini and mini 2 LCD's? I have a lot to go through so any difference that I can quickly glance at would be very helpful.
Thanks.
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Выбранное решение
I've found a difference.
If you're looking at the LCD from the back there is a small cable on the right.
On the Retina displays the cable comes up from the bottom of the display.
On the non-retina displays the cable comes from the side of the panel.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Would like a photo if possible
из
You know, I'm pretty sure you're right. But while looking for both images to show side by side, Google shows both the ribbons the same. I did notice the strip across the bottom missing from the mini1. Tho I can currently only vouch for the mini2 in front of me.
-Both of these images are from a Google search result. I am not the photographer. All credit goes to them, and all that jazz.
Счет 0
Добавьте свой ответ
RegencyTech буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 2,612
