How do I change the spark plugs in a 2014 honda civic
how do i change the spark plugs in a 2014 honda civic ex sedan
Это хороший вопрос?
Это хороший вопрос?
The tools you will need is a 10mm socket, 14 mm spark plug socket and 4-6 inch extension for the 3/8 ratchet. when looking at the engine bay you will see a orange dip stick just below that you will see for four flat surfaces with wires going to them. un-click the plugs from the coil packs and remove the four 10 mm bolts. Remove the four coil packs with in the tubes you should see the spark plugs if you do then get the spark plug socket and extension and and remove the plugs counter-clockwise. I rec's factory spark plugs so you dont have to gap the plugs. then add a small amount of anti-seas to the plugs and reinstall the them to factory torque. then the coils and connectors.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,962
