remove back panel = void warranty?
Hey, If you remove the back panel to check for water damage on the water sensors, will the warranty be voided? I just want to remove, check, maybe dry it a bit if water is in there, then put the panel back on.
It doesn't look like, from your pix and other videos I've seen, there is anything that would indicate the back panel was removed. Is that so?
Also, does the bleach work on the water sensors? Are the water sensors exposed areas the only areas that would be checked by an Apple Tech when you send it back?
Tnx
Это хороший вопрос?
