Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
554вопросов Показать все
mower won't start when hot.
after cutting half the lawn the mower stops and will not restart.
Это хороший вопрос?
Оценка 3
2 Комментариев
,check fuse, it bad, replace I would replace it anyway, sometimes they look his but arent
из
My battery is good but when I turn the key I get zero turn from the mower
Engine. The light near the ignition isn't lighting up either.
из
Добавить комментарий
3 Ответов
Выбранное решение
First check the vent in the gas cap. If it is not working, a vacuum will build up in the tank and starve the engine of fuel. After it sits for a while the pressure will equalize and it will be able to get gas again. Also if it has coolant, check the level.
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
I have this problem on a 2 cycle string trimmer. How do I check the gas cap?
из
I'd ask a new question on this. I do not have an answer.
из
You could just open the cap and release the negative pressure. Instant equalization. If it restarts, replace the cap. Can't be too expensive.
из
If the starter motor turns slowly like the battery is discharged , it could be a faulty winding. Some small engines use the same circuit running through the starter to the ignition system. If the starter motor is drawing too much juice it will cut back the power available to the ignition.
Оценка 2
I had the same problem and it got progressively worse by shutting off sooner and sooner over one summer. I had the carburetor serviced, but still had the problem. The final solution was to replace the fuel shut off valve in the bottom of the carburetor. This part appeared to be ok, but engine heat buildup would make it fail--an inexpensive repair to a vexing problem! My sincere thanks to a local "back-yard" mechanic who gave me this tip.
Оценка 0
Добавьте свой ответ
gclcars будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 39
За последние 30 дней: 177
За всё время: 18,571
