BlackBerry's newest flagship that features a physical keyboard.
73вопросов Показать все
Can blackberry passport water damage be fixed?
My blackberry passport fell inside water. i picked it and dried it and it worked for about a week till it suddenly went off and won't power up again.
I've taken it to the repair and i'm told i need to change the panel which is unavailable in the Nigerian market. please where can i get the panel. also will it be possible to fix this phone
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
No change for main board needed ask technician to remove ( brake ) one rectangular resistor between battery connector and display connector. If phone have water inside this resistor change and drain battery to 0 and prevent charge. I do same on may Passport and it working after one minute charging.
Был ли этот ответ полезен?
Оценка 0
yes its possible the phone will work, what ill like you to do is to contact me or watsap me on 08030732622,you be happy you did
Оценка 0
1 Комментарий:
hi chucks kindly sendme a watsap message on my contact,im based in Abuja we will discuss how in get the phone for repair
из
Добавьте свой ответ
chukseboagwu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 1,825
