How do I change my fuel filter
What steps and how do I change the fuel filter in my 2010 Honda Civic?
Это хороший вопрос?
Оценка 4
1 Комментарий
Location of fuel filter on Honda covic
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Albert Miller, it is bundled with the fuel pump, pressure regulator, and fuel level sending unit in the gas tank. There is an access panel in the trunk in the middle of the floor right behind the rear seats
Был ли этот ответ полезен?
Оценка 5
Your car does not have an (external) fuel filter like older Civics. It does have an in-tank filter that is connected to the fuel pump, which is in the fuel tank.
Оценка 2
1 Комментарий:
How would i drain all the fuel out ?
из
This might help you. https://youtu.be/wzRdwpUJ1OM
Оценка 2
On most modern vehicles, the fuel filter, fuel pump, sensors, and other ancillary hardware are all located in the gas tank. They're designed to last the life of the vehicle and as such aren't easy to service. Gasoline is pretty clean these days so there's little reason to change the filter unless you have a specific reason.
Оценка 1
Pick problems in hilly areas. Sometimes raise in temperature by two bars
Оценка 0
1 Комментарий:
My 2006 Honda Civic hybrid keeps jumping as I'm driving what would cause this
из
Добавьте свой ответ
Albert Miller будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 111
За последние 30 дней: 464
За всё время: 47,269
