Repair guides and support for your LG TV.
1343вопросов Показать все
HDMI Ports Suddenly Not Working
Verizon Fios Cable box signal still works fine on TV. The trouble is with the HDMI ports. We have an Apple TV, Sony BluRay, and LG DVD/surround sound unit each plugged in to the HDMI ports. None of them work, except for the Apple TV, but that signal shows with "snow" running over it. For the others, a "no signal" message appears on the screen when you select their input. I should note that each of these devices has been plugged into these ports for two-four years without trouble.
Это хороший вопрос?
Оценка 5
Добавить комментарий
1 ответ
A common problem w LG:s HDMI switching IC.
Follow the circuit lines from HDMI ports and heat that IC with a heatgun. First time it worked for three months, second time only one week…
Have to replace that IC or main board some day.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jessica Olson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 2,193
