14" business laptop released in 2014. One of the first Haswell business laptops on the market.
Вопросов 13 Показать все
Why doesnt my computer work properly?
I dropped my laptop from a table.After dropping from table it worked for sometime and after sometime my HDD LED light didnt work.When I tryt to open computer the screen goes white and opens after longtime.Te HDD light glows for sometime and gets off.My computer works when the HDD light gows but get dead when it is off.How can I solve my problem?Is my motherboard dead?
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Выбранное решение
Hi, It sounds to me that your hard drive was damaged when you dropped your computer. You probably need to replace the hard drive and install a fresh copy of the operating system. If you don't have a disk you can probably get one from Dell for a low cost. I am providing a link on replacing the hard drive. Hope this helps.
http://blog.parts-people.com/2014/10/28/...
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
I agree with rj713. You most likely damaged the platters in your hard drive when you dropped it. If you can't get data off it that you need, check out SpinRite from Steve Gibson's Gibson Research Company. The link is http://www.grc.com. Once you've recovered the data (if you can), install a new HD in the computer - I recommend an SSD, which has no moving parts - and reinstall your operating system.
из
Добавьте свой ответ
Pradip Thapa будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 787
