The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
32вопросов Показать все
Beats pill not Charging
My beats pill is not charging. Can it fix?
Это хороший вопрос?
Оценка 24
3 Комментариев
My beats pill won't work either I've been pretty rough on it and so when I plug the charger into the speaker I've accidentally pushed the metal part inside the pill and it won't charge
из
mine is in great condition but when i plug it in nothing happens and after 3 hours of charge it did not turn on
из
my beatspill has been broken for months and the metal part inside the charging part like moves around and when i put in the cable it just falls out! please help
из
Добавить комментарий
6 Ответов
Наиболее полезный ответ
A very prevalent problem in lots of bluetooth speakers, including the Beats Pill. The micro-usb spec doesn't specify a robust enough attachment to the motherboard. Over the course of use, the jack is literally pushed off the PCB, sometimes (often) taking the traces off with it. The replacement of the micro-usb jack is very often not straightforward at all, particularly when the traces have been lifted off. If you have skills, it can be done, but if not........
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I had a guy push the wrong charger In it it bent the pins just need parts looks like easy fix I ha VB e eltronic skills where do I find those parts
из
You'll want to troubleshoot the issue to narrow down the failed component.
  • First check your wall outlet, make sure it's providing power
  • Check the charging cable against another, known working, cable to verify that works.
  • Use canned air like Dust-Off to clear out any debris in the charging port itself.
  • Use the guide on our website to open up your device and replace the charging port if necessary.
Оценка 0
MGOM. Bluetooth speaker trun off not properly
Оценка 0
What you need to do is charge it as much as you can than turn it on after that hole the "b" button and the power button hold it the red light from the charging input will turn green and back to red three times
It should work after
Оценка 0
1 Комментарий:
Hi. I have done that but it won't hold charge at all do you have any other ideas? Thanks
из
My beats pill not charging
Оценка 0
Where can I get it fix
Оценка 0
Добавьте свой ответ
Phinisia Thomas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 43,606
