Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Proximity sensor not working after screen replacement
Hello.
I have replaced my mom's screen on her iPhone 5c as a Mother's Day present, and both her and I are happy with the results. Anyways, for the past 4 days, my mom told me that when she's on a call, she accidentally presses button not the call menu (mute, dial pad, end button, etc). When she told me yesterday, I immediately knew that it was the proximity sensor, and I told her that was fixable. Earlier today, I opened up my mom's iPhone, and noticed the proximity sensor bracket on the original screen. I transferred that bracket to the new screen and put the iPhone back together. I called myself from her iPhone to test the sensor. The display turned off for like a second and it turned back on. It did that for like 3 times before the sensor wouldn't work anymore. Later on, like 3 hours later, I opened it up again and reseated the flex cable. I put the iPhone back together and it didn't work. 5 minutes later, I called myself again and the sensor was working! Then 20 minutes later, I called myself again to make sure that it was working again, but sadly it stopped working. I don't know what to do anymore to fix this. I kept looking online to fix this problem, and they didn't help. Right now the iPhone is functioning without the proximity sensor working.
Does anyone know a solution to fix this? It would be greatly appreciated!
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi Brandon,
It's very possible that you have damaged it, replacing it should solve your issue. :)
Был ли этот ответ полезен?
Оценка 1
You have to insert the sensor INTO the sensor holder.
Оценка 0
2 Комментариев:
I have inserted the sensor into the sensor holder. I double checked and it was on there securely.
из
If nothing work, you have broken front camera flex...
Change it.
из
Добавьте свой ответ
Brandon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 302
