Device repair information and troubleshooting for the Dell XPS 15, released in 2010. Possible model numbers include L501, L501x, L502, and L502x.
4вопросов Показать все
Dell XPS L502X Booting problem showing only green screen
My system won't boot it will start but the screen remains green and if force shut down it will ask me either to lunch windows repair or start normally either of the one i do still it didn't work
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Think it is impossible to flash the bios outside windows, so options are to try to reinstall windows, or mess with the bios settings to see if there is a way to flash it. Of course that is if it is a software problem and not hardware. If it is hardware there are a few utilities that can help diagnose the problem, good luck finding parts though. Best option for parts, is to call up dell and ask for their parts department. They can help find the correct parts for your computer, if they still have replacement parts that are compatible then you're in luck, otherwise, it isn't going to be easy to find them second hand.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
ONESIMUS JOHN W будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 457
