Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why I can't charge my phone
My charger piece in the inside of the phone where i charge my phone is damaged how can i fix it
Это хороший вопрос?
Оценка 5
1 Комментарий
i want where to take phone it to fix the charge pots
из
Добавить комментарий
Ответов (4)
Наиболее полезный ответ
Hellow Caleb Ragsdale,
you can simply change the [http://daughter card |Why I can't charge my phone]
here is the teardown guide
if you have sound soldering skills you can change the charging port and it will cost around $2
Был ли этот ответ полезен?
Оценка 3
Where do I find that for my phone can charge and how do I find it
Оценка 2
how do i fix the charger port on on my phone it is broken
Оценка 0
I had my prongs bent in by someone so I want to connect positive and negative inside to my charger wires BUT it has 2 red 2 black and 2 white, what to do? :( its a alcatel one touch fierce xl :( . + and - not labeled.
Оценка 0
Добавьте свой ответ
Caleb Ragsdale будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,157
