Pairing button is jammed, after being dropped
Hi,
Can anyone send me a step by step guide to repairing the pairing button on a Big Jambox after it has been dropped.
The speakers still work with a cable, but the pairing button is jammed and cannot be pressed.
Это хороший вопрос?
Счет 1
1 Комментарий
The rubber/plastic part of the pairing button is probably just misaligned from the actual button inside. If you pry up the side panel a little near the button, it will usually re-seat itself.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Using a plastic spudger or pry tool, lift up the side panel near the pairing button. You might have to massage the button a bit as you do this, but it should re-align the plastic nib to the actual button inside the speaker.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
I initially thought I had to scrap the speaker. Thanks a lot for the fix! Worked to perfection...
из
Ivan, I know that the big jambox can be put into pairing mode by pressing a combination of buttons, do you know what that combo is?
из
Unfortunately, I don't know if there is one. Sorry. The fix did work. The speaker is now dead because the battery won't recharge anymore... :(
из
Добавьте свой ответ
Kkc буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 4,726
