The HTC Desire 510 Android smartphone was announced August 2014.
46вопросов Показать все
Why is my phone not charging?
-Updated software on Thursday
-Charged fully on Friday night
-Used all day Saturday
-At bedtime, not unusually dead
-Plugged in to charge and it kept notifying me that the charger was connecting then disconnecting.
-Was using same charging cord as I usually use, tested it on another phone and it was fully functional.
-Phone is now too dead to turn on and shows no signs of charging.
HELP!!
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Either your battery is completely dead, your charging port on your phone is broken, or you damaged your battery/phone. Take it to a repair store, Sprint, or Best buy/Geek Squad to check it out.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Dude we fixit here on ifixit thats the idea of ifixit
из
This could be a battery issue if you have another to try start there if your getting a connect disconnected it sounds like it could be the charging port itself . Try wiggling the cord and see it there's a position that will allow it to charge
http://www.amazon.com/Original-Genuine-C...
the port can be purchased on amazon and is a separate unit so its screw in and hook up your cables and away you go
Оценка 0
Добавьте свой ответ
Ashley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 669
