Ноутбук от Toshiba с дисплеем 15,8 дюйма, работающий под управлением Windows. Процесс его ремонта довольно прост и похож на большинство других ноутбуков. Для выполнения работ потребуется только отвертка.
K O'd my laptop
In a fit of rage and stupidity ,I slammed my laptop closed and now it is inoperable. I have a windows Vista factory out of the box recovery program but it will not recover. It will load first disc and second disc but 32% through the recovery it has an error and shuts laptop down. Do I need a replacement laptop along with anger management ? Lol
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Hi Ebert, While the machine is running, place your ear next to the machine and listen for any signs of hard drive failure. Provided you have a mechanical hard drive, sounds of spinning up, clicking/clunking and then spinning up again, etc. may be signs that you accidentally damaged the hard drive. A healthy mechanical hard drive has somewhat of a chattering/popping sound. Also--depending on just how hard it was slammed--It may be a good idea to 're-seat' the memory, as a poorly seated chip may become partly dislodged in the even of jarring. Start there, and please let us know how it goes.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Ebert Williams буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 476
