The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40вопросов Показать все
I have antifreeze coming form the exhaust
I have a 1997 jeep cherokee sport. It was over -heating due to a cracked radiator..So I replaced the radiator and still overheating. I than took off the thermostate and now I have antifreeze coming form the exhaust...HELP what is this...
Это хороший вопрос?
Оценка 0
1 Комментарий
why do you think it is anti-freeze?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
In best case you have just blown head gasket... In worst cracked engine block or head.....
Был ли этот ответ полезен?
Оценка 1
Look at you're oil cap ware you put oil in and If you see like a frothy look to it you probably have a bad head gasket you can also look at the dipstick and if its higher than what its supposed to be you probably have a head gasket problem. If it is a head gasket when you take the head off take a really straight and flat peace of meateal and go slowly across the head in all directions and if you see any gaps even a little one take it to a machine shop and have them shave the head otherwise if you just put a new gasket on it will still leak also look for cracks . You could have them preasher test it as well it should all cost about 60 or so.
Оценка 1
Добавьте свой ответ
smilez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 239
