Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382вопросов Показать все
How to clean dust from inside system
Hi,
I have a Mid 2010 27 inch iMac model 11,3. It's now been in use for four years. If this were one of the old tower PC's I would have already opened it several times to clean all the dust out of it. Is there somewhere I can learn how to do that on the iMac? I ask because if I watch Netflix I have noticed that the top of the back gets very hot.
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hey mate, this manual should help you out:
http://tim.id.au/laptops/apple/imac/imac...
Also as a note, I'd remove and check the fans for derbies (such as hair) in its assembly
Hope it helps.
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
Thanks Zakk. This is great.
Appreciated!
из
Dude, zakk; you're the man. Thank you so much. This is going to be super helpful. I have an iMac 27 2011 model but I'm assuming most things should be similar. Wouldn't you say?
из
Hey J.w. sorry mate, I only just realised you'd commented now. Yer it should pretty much be the same thing. If you get stuck, just comment again.
из
Does anyone know the shortcut buttons to expel dust using fans.. i've seen it once but cant remember
из
Добавьте свой ответ
MTek будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 23,909
