Nokia Lumia 630 / 635. Выпущены в Июне 2014'го года. Две эти модели отличаются только наличием 4G модуля.
54вопросов Показать все
Why does my phone always turn off randomly
My phone always randomly turns off, I would be texting someone and then it would (sometimes) flash and then turn off and its really annoying me, and sometimes when this happens my phone will be at 50% 60% etc and the phone will say its dead... Plz someone help me as I don't have a clue what's going on?
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
MOST probably: It would seem the battery is damaged and needs to be replaced (did you dropped your phone?). Could you ask a friend for a temporary battery swap to check this, or buy a new one.
Optional: Also, consider doing a factory state formatting, this could solve not only this issue, but make your phone faster (it "refreshes" the phone), but take precaution with your data (remove the SD card!) before that and copy all your contacts to your email provider account (meaning, do not have only one copy of the contact, as the formatting will erase your personal data on the phone), write them on an office excel sheet or paper if necessary.
Hope it serves you.
Narmith
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you and I did do a battery swap however all that happened is my phone turned on but the screen went pure blue and stayed pure blue and yes I did recently drop this ??
из
buy a new phone.....
Оценка 0
Mine switches on and off and then it takes a couple days tell it switches back on
Оценка 0
1 Комментарий:
so it did turn on aagain and continue working normally?
из
Добавьте свой ответ
josh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 16
За всё время: 3,795
