Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
only runs with the choke on
Mu trimmer starts but will not run when I shut the choke off
Это хороший вопрос?
Счет 0
1 Комментарий
How old is it?
из
Добавить комментарий
4 Ответов
Выбранное решение
High speed mixture needle is in the body of the carb under below the primer.
That brass collar with the plastic plug in it - thread a sheet metal screw in there and pry it out with a pair of side-cutter pliers. The whole brass thing can go, it just holds the plug.
Then you can adjust your "non-adjustable" carb.
Был ли этот ответ полезен?
Счет 4
2 Комментариев:
Still doesn't work. Same deal. All the way in or all the way out, still won't idle. Even replaced entire fuel system.
из
Spot on to this day. Sheet metal screw worked easy to remove cover and mixture needle adjustment solved high speed issue of no run without choke.
из
If it starts with choke on then your carb needs cleaning or adjusting.
Счет 0
3 Комментариев:
Its been cleaned new diaphragm where do you adjust it & how?
из
Bullshit. Even with a new carb this can happen.
из
What if your carburetor has no adjustment screws other than idle screen
из
There is apparently an adjustment screw, but it is hidden and you need to pull the plug hiding it out to get to it. The local mower repair thieves want $70-$90 to install a “carb rebuild “ in it, which consists of a few gaskets and maybe new fuel lines and fuel filter, for sure $90 if they change those.
The good news is, a new carb, two pump bulbs, two fuel filters, an air filter, spark plug and new fuel lines can be had for a very easy to swallow price of $10.50 to 22.50, most being $13.50 on ebay. It is quite easy to put the new carb on. I understand they need to make money but $70-$90 for a few dollars (literally) of gaskets and lines on your old carb is over the top.
Счет 0
1 Комментарий:
Same problem with entirely new fuel system.
из
Take the wee filter off that is on pipe in tank .it dont need it..them strimmers are a f…. nite mare
Счет 0
Добавьте свой ответ
Lisa Pendleton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 51
За всё время: 23,348
