Where can I purchase replacement parts for the jawbone Big Jambox
where can I purchase replacement parts for the Jawbone Big Jambox
Please
Это хороший вопрос?
Please
Это хороший вопрос?
Hi there .I had the same problem trying to get a part for my big jambox even phoned jawbone customer services they couldn't help .They said in Northern Ireland they don't have parts stocked .I don't know about other parts of the uk.Even looked on the jawbone website with no success.Your best bet is to buy the full unit and take the part you need of the unit .You can buy on ebay big jambox faulty normaly with a bluetooth problem.Its a bit hit and miss what price you will pay for one sentence they are up for auctioned starting price at 0.99p . For example I bought the full unit for £12.00. And an hour later on a other auction I bid on one and it sold for £30.00.But I'm pretty sure the part your looking for will cost a lot more than that.If you can find a part somewhere else.I Hope this is some help to you.
Был ли этот ответ полезен?
Sorry I should have mentioned on the above message i posted.The ebay seller will list the exact fault with the big jambox.As I mentioned before it's normally a Bluetooth fault.Paul.
very good suggestion, Paul! I have done this for other electronic repairs but didn't think of in this instance
ebay has parts get them while they last.
I have a Big Jambox, Jawbone Model-J2011,SNJ201124410679D1The power plug came loose and tore up the board and all the foil with it, so where can I get a new board, I tried to trace out the board no good .The board has a number on it if that is any help (JAMBERRY_Side_Rev-A 701-00007-A
I have looked all over the place no good.
Thanks Art. aguyer10@verizon.net
Same here, I need the exact same board to fix mine as well,
The heaphone female jack need to be replaced, I intend to change out the whole board. Please contact me if any one finds the circuit board
djchango.cz@gmail.com
Did you found that board yet?
If you guys could send me photos of your boards, I really don't think you need to replace the whole board if it is just the AC power post that is amiss...I did some edits to the instructions in this regards...perhaps they weren't approved as they were rather wordy and stream-of-conscious (i.e. unedited) but I did include some rather good photos of AC power posts and where to order them and how to use any AC power post that fits your cord plug (which is easy to modify as well) AND fits in the given space allotted for the AC power post AND has the 3 contacts (+, - & ground) oriented similar to the original AC power post contact connections as these are fairly easy to modify. I even included a photo of my installation of a salvage AC power post in my Big Jambox.
Ebay has parts get them while they last.
jasonedwardkirk can you send me the details on how to replace the AC power post? prcdano@gmail.com
I have a spare red Jawbone Big Jambox that I am going to part out because there seems to be enough people on here need parts...the only part I know I don't have is the outer grill/casing. I also figured out a way to replace the AC power plug PCB post with just about any post but am in a rush now...however, please feel free to gmail me at jasonedwardkirk regarding anything herein...cheers!
sorry but I had a family emergency and I am now back on email should anyone still need the red Jawbone Big Jambox I am selling for parts...it is missing the battery...also, I have a BRAND-NEW in the box Jawbone Mini Jambox (graphite) that retail for $80 that I would be happy to work into the deal or sell separately...anyway, I am back in touch with cyberspace, email, etc....jasonedwardkirk at g mail...oh, and I hope to make a video of how I replaced my AC power post onto the PCB of my Big Jambox, too
Omg yes please my email is ps3infokslebkiller I would appreciate it so much if u where able to give me the battry as long as it's working ahah glade to see its not just me with this problem
I need a replacement end plat with the power and parting buttons
ebay now has parts for the big jambox get them while they last.
hi i need one of the speakers lufer40@hotmail.com
Hi,
I have big jam box model J21011 and required to chang both speaker , where could I purchase ?
as of today ebay has parts, check it out.
I need button panel for jawbone jambox can u plz help me
ebay has parts, ask the seller if you do not see the part you need. I am pretty sure I have the part you need.
I need button panel for big jawbone jambox. Can somebody help me
Look on ebay. Are you looking for the plastic power button or the actual charging board. Just search Big Jambox parts and you will see alot of parts. If you dont see what you are looking for message the seller redstalun.
Which parts in particular are you trying to procure?
Hi Jason, I have a Big JamBox purchased back in 2012 of which I'm pretty sure the battery life is over having tried to charge it many times..checked battery voltage..zero..contacted Jawbone..they wouldn't give me a live expectancy on the battery or sell parts, basically directed me to their website and a atta boy to close the case.probably because I'm a technician and I'll figure it out..I didn't have a whole lot of luck finding a battery should I just keep searching?
if you can´t find the battery, can you sell me the charge port?, please Peter Edson
Where can i get a replacement shield for my big jambox
За последние 24часов: 6
За последние 7 дней: 16
За последние 30 дней: 36
За всё время: 12,115
3 Комментариев
I have a Big Jambox model -- J2011 / serial # J201123003809D1. The unit works but doesn't work via the battery. It needs to be plugged in all the time. I assume the battery is not working anymore.
Where can i get this battery to buy so it can be replaced??
из HILARY
Ebay now has parts for big jambox's. Get them while they last.
из redstalun
build your own with 3 -18650 lithium ion cells!
из john vanlandingham
