Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75вопросов Показать все
Glass only repair not digitizer
I only want to replace the glass, not the digitizer for my phone. How is this completed?
Это хороший вопрос?
Оценка 1
1 Комментарий:
To do this properly would involve you spending much more than a new assembly would cost. Would not recommend.
из
Добавить комментарий
1 ответ
The way a samsung display is built, you can certainly replace just the glass. The s5 active (and regular s5, very similar displays) are super thin and easy to break but if you've gotten into something into a layer of the display other than the glass trying to remove it, its likely the polarizer not the digitizer.
Basing my assumption of your repair level abilities on your question, I'd advise you not attempt this repair without substantial further research.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
dlacher будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,513
