Nokia Lumia 630 / 635. Выпущены в Июне 2014'го года. Две эти модели отличаются только наличием 4G модуля.
54вопросов Показать все
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
Это хороший вопрос?
Оценка 4
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
из
lumia 635 power baton bord not warking
Оценка 0
Добавьте свой ответ
gobstopper2 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 966
