power base giving off a burnt plastic smell
After blending with the nutri bullet there is a burnt plastic smell coming from the power base.
Это хороший вопрос?
Это хороший вопрос?
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm Eastern Time). You will be required to provide the barcode/serial number located underneath your Motor Base
Был ли этот ответ полезен?
Mine is not under warranty but smoke is coming from thebase unit
The blade assembly can fail and does not rotate freely, then you get additional friction overloading the motor, hence the smell and smoke.
The blade assembly fails regular,
Karen, could be the motor bearing or the motor winding etc. Unless you take it apart using these guides it will only be a guess.
За последние 24часов: 4
За последние 7 дней: 30
За последние 30 дней: 174
За всё время: 50,544
3 Комментариев
I just bought a nutri bullet and After blending with the nutri bullet there is a strong burnt plastic smell coming from the power base. Why?
из sandhanamkasi
Hi I have the same problem, as soon as I started there was a spark and burnt smell. Was your problem resolved? What should I do?
из Mansi
I had that too. Took it back and have the same problem
из cecille heath
