Washer doesn't drain completely
My washer doesn't drain completely. I anticipate that the drainage system may be clogged with a sock or something. How do I get to the item to remove it?
Это хороший вопрос?
Это хороший вопрос?
Jamar,
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
remove the water pump. Here is the guide for it. Check to make sure there is no obstruction. Usually, if it is clogged, it won't drain at all, but check it and see what you find.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 1,738
