Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66вопросов Показать все
Some portion of motherboard is overheating
When the battery was inserted then the portion 2 inches below the f1 fuse was overheated but when i plug in the power then there was short circuit two inches away from the right side of touchpad and smoke came out...
What happened to it ? And what should i do now?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
At our labs we hook up an external adjustable PSU and slowly increase the amps whilst monitoring with thermal imaging camera for overheating components. Once found we replace them and repeat the process until the board is repaired. Some of the components can also be tested in-circuit, so would suggest testing all diodes and resistors around the area that gets heated up.
Был ли этот ответ полезен?
Оценка 2
solder whatever component that was heating up off the logic board afterwards, plug the charger it again to see if it still heats up.If it doesn't that mean the component you removed was damaged and needed to be replaced.
Оценка 1
Добавьте свой ответ
nomanghous будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 198
