Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
Вопрос закрыт
speaker not working after changing the power flex
Hi folks
I have replaced the power flex on a 4s but now the speaker don't work. Any ideas what the problem could be?
I haven't damaged the speaker the only thing I did was peal it off the old power flex.
I thought possibly the speaker was sitting lower and not touching the mother board so propped it up a little but still not working.
This is the second time this happened to me, the last time i just put a new speaker in and it worked perfect.
thanks in advance
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Is this a four CDMA or an AGM?
It sounds to me like you got the speaker on upside down you might need to turn it around and make sure the two prongs are hitting the leads and if that does not work then you must the damage something in the speaker and removal of the PowerFlex cable or you could a got a bad power flex cable that does happen some Times
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 49
