The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114вопросов Показать все
Xperia z3 doesnt charge
Hey, my xperia z3 doesnt charge anymore. Only the red light is flashing. It has been connected for 10 hours now and i still cant turn it on. What could i do?
I tried the reset buton then volume + and power button and still nothing.
Does anyone know, what can i do?
Это хороший вопрос?
Оценка 2
2 Комментариев
My sony Z3 D6603 dont turn on anymore, never charge, never power on again, and I change the battery, when I plugged in with the wall charger or computer the led powered on for a few seconds and turn of, I did the comadand power + volume up and feel a vibration but never turn on any more, How can i fix my cell phone i think the problem is in the main board
из
Maybe you have the complete mainboard schema to know th number of all resistance, capacitor, condencer, IC
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
-Try to change the charging cable or adapter, if can solve the problem, that's the reason of broken cable or adapter.
-Try the magnetic charging. If can charge the phone well, the problem may be caused by wrong USB port. If can't charge either, your battery may be broken and need a replacement.
- If new battery can't save your phone, you need take it to check the motherboard.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
из
has your device started working again? i am facing the same issue at the moment. please help
Оценка 0
Добавьте свой ответ
infoservis112 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 2,027
