Repair information and support for walk-behind lawn mowers made by the Toro Company.
Why is gas pouring out of the air filter?
We started to use the lawn mower, which was fine last time we used it the beginning of summer. We started pouring gasoline into the gas tank and then gasoline started to pour out through the air filter. We did not spill any gasoline onto the mower. What could be causing this to happen?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
The needle is probably not seating correctly. The most likely cause is a bad float. A carburetor rebuild should fix it. If you’re pretty handy, it’s pretty easy.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Dee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 779
