Tablet keeps freezing up. can not power off.
Lately my Asus freezes up , unable to power off . having to use up battery until recharge, power up put it use for no more than 15 minutes then freeze.
Это хороший вопрос?
Это хороший вопрос?
Bachup all data.
Turn it off
Maybe you must use the reset trigger on the side
When it is turned off
Press volume up and hold it
And then push the Power button, while holding volume up
Hold till you see the Android with a helmet
Thats hatdreset
That may help
Everything will be erased
Был ли этот ответ полезен?
as karl5th said. I did the same and it works. Thank karl5th
Very helpful Thank you very much had same problem and it worked
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 3,112
1 Комментарий
Screen keeps freezing
из matthew piggott
