Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
Вопрос закрыт
Best way "remold" frame?
Hi, as everyone know, iphone 5 serie frame is very very fragile.
i just changed 5s lcd to a client and his frame was very very broken so when i clipped the lcd to the frame, lcd broke....
reason, the metal frame is very deformed and blocked some place where lcd going to.
so, i take metal blade and scrapped all the frame where it was broken, finaly after 45 min, i was able to put new lcd without damaging it.
so what is your best tips/way to "remold" frame to be able to put the new lcd ?
thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Выбранное решение
If the housing is dented, you can use a round edged metal spudger or flat head screw driver and a hammer to knock out the dents, you can also file it away and give it a smoother edge.
Or, you can also use a tool called gTool, expensive, but performs really well in pulling dents out and make it look pretty good to.
Был ли этот ответ полезен?
Оценка 3
I repair thousands of devices a year. Yes, I have a file set in among my tools but I've only used them a handful of times. Rarely should you have to resort to removing metal from a device.
I've also got a small brass hammer, various screwdrivers and spudgers I like to use to bang the phones and ipads back straight in addition to a set of G-tools. You should be able to straighten 95% of the phones you come across without removing metal. I've even seen people get the idea they need a dremel tool to hack at ipad frames with. I assure you, a dremel tool has no purpose in the world outside of your garage and shouldn't come anywhere near a cell phone.
Оценка 1
Thank you , will try the gTool :)
Оценка 0
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 176
