Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376вопросов Показать все
"Fluttering" lines on Display
The display has two 1-inch columns of lines that alternate on & off, "Fluttering," distorting the display with 1" black/white lines from the top to the bottom. The display on either side of the columns is normal in all other respects. When the iFixit window is open, and dragged across the two columns, the right hand column's fluttering is overwritten by the "Ask a question" content though the box around it, e.g., (red/yellow/green buttons, the top, blue iFixit toolbar, and the dock continue to flutter).
The left hand column continues to flutter, top to bottom.
My question: Is this a Display problem, needing a $700 display swap, or is it a Video circuit board problem, requiring Motherboard repair?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Connect to
an external display - if problem persists its the GPU (Video Chip)... if not it's in the cable/display circuit.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
+ agreed
из
It was the Graphics chip.
из
Добавьте свой ответ
jbarrick1 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 1,069
