The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
310вопросов Показать все
earpiece broke off in ipad
put erpeice into ipad section broke off in ipad now onle can hear on one side of earpiece and cannot get piece out to hear
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Randy, you can try your luck first with very fine tweezers, or a strong needle that you could heat to make it penetrate into the headphones CABLE not jack. Once you get hold of the cable, you can try to pry the tip of the cable out of the headphones jack with the needle while at the same time pulling out with the tweezers or pliers or your nails, if you can get a grip on it.
Был ли этот ответ полезен?
Оценка 1
You have to replace the audio pcb, it has the audio jack attached. Possibly you can get the piece out if you open up your device.
Оценка 0
Добавьте свой ответ
Randy Strickland будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 100
