What does 4SNS/1/40000000:Tm0P-63.375 in the hardware test mean?
I dropped my beloved ProBook, it got a bump in the unibody and the hinge to the screen is slightly off, making it not close properly.
I am devastated...
Noting seems to be wrong, except that the hardware test claims an error called 4SNS/1/40000000:Tm0P-63.375.
What does it mean? Should I expect a horrid expence from trying to have it fixed?
Best wises,
Simen, Norway
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
As I understand it a 4SNS error code indicates a sensor problem. Since the unit was dropped I would open it up and see if any cables are disconnected or loose. Other than that if the computer is working properly I would just continue to use it. Good luck Ralph
MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement
Был ли этот ответ полезен?
Оценка 4
1 Комментарий:
+ research
из
Very confusing.. but heres what I found on google. If possible, send it in to apple and claim warrenty.
Оценка 0
Добавьте свой ответ
Simen Iversen Vangen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,534
