iMac G4 17" 1.25 GHz Model M9168LLA PowerMac 6,1 introduced in 2003.
superdrive, hard drive and memory replace and upgrade
Has anyone attempted to take apart the iMac G4 17" 1 Ghz model. My DVD drive died and I figured while it is open upgrade everything I can. I have spare 1GB DIMM ram, spare 250 GB Hard drive and spare DVD drive, also that thermal paste. Any advice will be helpful, and if anyone has a step by step guide with pictures will also be appreciated.
Thank you.
Update
The upgrade went flawlessly, the machine is performing better than before.
FYI to install a OEM DVD/CD burner you must remove the entire plastic faceplate of the drive case.
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
Here's a 24 page instruction guide on the optical and hard drive replacement. This is one of the most difficult machines to work on that Apple ever made so take your time: http://www.faqintosh.com/risorse/en/guid...
Make sure you have the correct RAM, ATA/IDE hard drive and optical that will work.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Beat me again--here is an additional link to help. + Ralph
http://www.xlr8yourmac.com/systems/iMac_...
из
Добавьте свой ответ
Dinowarrior18 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 6,030
