hard drive connector problem
a little bit ago, my chromebook started having problems, after a bit of researching and looking at the hard drive, i think i found the problem, but could never find a solution.
the connector wasnt staying connected to the motherboard. i used to be able to pinch it to keep it connected, but after doing that a bit it stopped working all together. so i gave up
i recently heard of this place and figured i'd give it a shot here. i dont know if i need a new connector or a new set of cables. if i need a new motherboard connector, then good luck as theres a plastic support beam for the backing and i cant completely screw off the backing due to screw heads stripped. when they installed it, they tighened it way to much, even with the correct screwdriver and size, i just couldnt get it off.
Это хороший вопрос?
Счет 0
Добавить комментарий
