Blown resistor capacitor on the motherboard
Hi. I have a 11" Macbook Air and one of it's motherboard resistors had blow up.
http://s1.postimg.org/g2cffygfz/image.jp...
How to fix it?
Thanks!
Это хороший вопрос?
How to fix it?
Thanks!
Это хороший вопрос?
Vilson, that is C7540 which is a 62UF 11V 20% Tantalum - Polymer capacitor in a Case-B2S-1 package. You will have to of course solder the replacement back on. Biggest issue here is why it got damage. usually caused by a short circuit, so you will have to determine the cause of it.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,341
7 Комментариев
What exact model is your MBA? Give us the last 4 digits of your serial number so we can properly identify your hardware.
из oldturkey03
This is the serial number:
http://s15.postimg.org/int34ynor/image.j...
Where I can get that capacitor from?
из Vilson
I'd check with places like Mouser.com or Digikey.com. Of course there are plenty of others. Just a matter of looking around
из oldturkey03
Nothing in there. No idea where to look for it.
из Vilson
Check for some with a lightly higher value. You can use some that have higher values, just never lower. A Sanyo 11TJSF62MAIG would be a perfect match. Not easy to find in small quantities. You may have to scrounge on dead circuit boards etc.
из oldturkey03
Показать 2 больше комментариев
